Kingston Expands HyperX Memory Family
l         HyperX Predator Debuts with New Heatspreader, More Aggressive Design
l         Fastest Speeds, Lowest Latencies and Highest Capacities
Hsinchu, Taiwan – August 17, 2012 Kingston, the independent world leader in memory products, today announced the launch of the new Kingston HyperX Predator. The new high-performance DRAM module complements the HyperX product range with the fastest speeds, lowest latencies and highest capacities. HyperX Predator is aimed at extreme enthusiasts and overclockers looking to push their systems to the maximum with the fastest speeds and highest performance hardware.
With its new heatspreader, HyperX Predator offers a more aggressive design, which accompanies the look and design of the latest PC hardware, and provides great heat dissipation to optimize memory reliability. The memory part number ends with X is Intel XMP certified, and all Hyper Predator has been fully tested and validated on a top range of motherboards currently available on the market. End users can easily overclock their systems by simply selecting a profile in BIOS with no need for manual adjustments.
“The PC gaming market is robust and growing and we are pleased to contribute to that market with our new, more aggressive HyperX Predator memory kits,” said Ann Bai, DRAM Sales Director, APAC region, Kingston. “Enthusiasts will experience higher performance, ultra-responsive multitasking possibilities and an overall faster system thanks to its top optimized performance settings for specific modules ― handpicked and tested by our Kingston engineers.”
HyperX Predator is available in speeds up to 2666MHz; CAS latencies of 9 and 11; and capacities from 8GB to 32GB in various dual- and quad-channel kit configurations.
Kingston HyperX memory is backed by a lifetime warranty and free live technical support. For more information, please visit www.kingston.com/en/memory/hyperx.
Kingston HyperX Predator Specifications:
  • Capacity: 8GB, 16GB, and 32GB in kits of 2 and 4
  • Frequency (speed): 1600MHz-2666MHz
  • CAS Latency: CL 9, CL11
  • Voltage: 1.5v -1.65v operating voltage enables stable overclocking
  • XMP Certified: Higher-performing frequencies, timings and voltage are attainable by simply enabling Intel’s Extreme Memory Profile
  • Compatible: Designed specifically for P55, H67, P67, Z68, H61 (AG), and Z77 Intel chipsets; as well as A75, A87, A88, A89, A78, and E35 (Fusion) AMD chipsets
  • Reliable: 100-percent tested
  • Guaranteed: Lifetime warranty, Free technical support
Part Number Capacity and Features
KHX16C9T2K2/8 8GB 1600MHz DDR3 Non-ECC CL9 DIMM
(Kit of 2) T2 Series
KHX16C9T2K2/8X 8GB 1600MHz DDR3 Non-ECC CL9 DIMM
(Kit of 2) XMP T2 Series
KHX16C9T2K4/32 32GB 1600MHz DDR3 Non-ECC CL9 DIMM
(Kit of 4) T2 Series
KHX16C9T2K4/32X 32GB 1600MHz DDR3 Non-ECC CL9 DIMM
(Kit of 4) XMP T2 Series
KHX18C9T2K2/8X 8GB 1866MHz DDR3 Non-ECC CL9 DIMM
KHX18C9T2K2/16X 16GB 1866MHz DDR3 Non-ECC CL9 DIMM
KHX18C9T2K4/16X 16GB 1866MHz DDR3 Non-ECC CL9 DIMM
KHX21C11T2K2/8X 8GB 2133MHz DDR3 Non-ECC CL11 DIMM
KHX21C11T2K2/16X 16GB 2133MHz DDR3 Non-ECC CL11 DIMM
KHX24C11T2K2/8X 8GB 2400MHz DDR3 Non-ECC CL11 DIMM
KHX26C11T2K2/8X* 8GB 2666MHz DDR3 Non-ECC CL11 DIMM
* KHX26C11T2K2/8X will be coming soon.
