Kingston Ships HyperX Memory Kits with Black PCB
• HyperX Beast and black Product Lines to Feature Black PCB
• All-black Look Complements System Builds Where Color and Design is Key
Hsinchu, Taiwan – March 26, 2013-Kingston, the independent world leader in memory products, continues to celebrate its 10th HyperX anniversary by announcing all-new black printed circuit boards (PCB) on two of its product lines. Kingston’s high-performance HyperX Beast and entry-level enthusiast ‘black’ lines will incorporate black PCB under the signature heatspreader designs.
HyperX Beast, a part of the Predator family, matches large capacity with ultra-fast frequencies. Now featuring black PCB, HyperX Beast is available in various dual- and quad-channel kits in capacities from 8GB to 64GB and speeds up to an ultra-fast 2400MHz. It is perfect for hardcore gamers, PC modders, content creators and overclockers. The 2133MHz, 64GB and 2400MHz, 32GB Beast memory are the fastest and highest capacity certified IntelXMP-ready kits on the market.
HyperX black is available as single 4GB and 8GB module or as an 8GB or 16GB dual-channel kit in 1333- or 1600MHz frequencies. HyperX black is ideal as a cost-efficient performance upgrade for an overall faster system or for increased in-game frames-per-second rate.
“Our customers and fans have asked us to come out with HyperX memory featuring black PCBs to better match their system designs,” said Ann Bai, DRAM Sales Director, APAC region, Kingston. “We are able to match good looks with high performance. The black on black combination allows for easy pairing with any color component on the market.”
Kingston HyperX Beast and black Memory Features and Specifications:
- Unique: features a dynamic new heatspreader to maximize thermal dissipation, features a Black PCB
- XMP profiles: easy to enable, factory configured for best maximum performance
- Reliable: 100-percent factory tested
- Guaranteed: lifetime warranty, free technical support
- Easy to install
- Capacities: 4GB, 8GB, 16GB, 32GB, 64GB in various kits of 2, 4 and 8
- Frequency speed: 1333MHz−2400MHz
- Operating temperature: 0°C to 85°C
- Storage temperature: -55°C to 100°C
- Dimensions: 132mm X 41.4mm (Beast),133.35mm X 30mm (black)
- Available in a variety of CAS latencies
- Voltage: 1.5V-1.65V
- Compatible: tested with all popular brands of motherboards
- DDR3 only
Kingston HyperX Beast Memory1 |
Part Number | Capacity and Features |
KHX16C9T3K2/8X | 8GB 1600MHz DDR3 CL9 DIMM (kit of 2) Beast series XMP |
KHX18C9T3K2/8X | 8GB 1866MHz DDR3 CL9 DIMM (kit of 2) Beast series XMP |
KHX21C11T3K2/8X | 8GB 2133MHz DDR3 CL11 DIMM (kit of 2) Beast series XMP |
KHX24C11T3K2/8X | 8GB 2400MHz DDR3 CL11 DIMM (kit of 2) Beast series XMP |
KHX16C9T3K2/16X | 16GB 1600MHz DDR3 CL9 DIMM (kit of 2) Beast series XMP |
KHX16C9T3K4/16X | 16GB 1600MHz DDR3 CL9 DIMM (kit of 4) Beast series XMP |
KHX18C9T3K4/16X | 16GB 1866MHz DDR3 CL9 DIMM (kit of 4) Beast series XMP |
KHX18C10T3K2/16X | 16GB 1866MHz DDR3 CL10 DIMM (kit of 2) Beast series XMP |
KHX21C11T3K2/16X | 16GB 2133MHz DDR3 CL11 DIMM (kit of 2) Beast series XMP |
KHX24C11T3K2/16X | 16GB 2400MHz DDR3 CL11 DIMM (kit of 2) Beast series XMP |
KHX24C11T3K4/16X | 16GB 2400MHz DDR3 CL11 DIMM (kit of 4) Beast series XMP |
KHX16C9T3K4/32X | 32GB 1600MHz DDR3 CL9 DIMM (kit of 4) Beast series XMP |
KHX18C10T3K4/32X | 32GB 1866MHz DDR3 CL10 DIMM (kit of 4) Beast series XMP |
KHX21C11T3K4/32X | 32GB 2133MHz DDR3 CL11 DIMM (kit of 4) Beast series XMP |
KHX24C11T3K4/32X | 32GB 2400MHz DDR3 CL11 DIMM (kit of 4) Beast series XMP |
KHX18C10T3K8/64X | 64GB 1866MHz DDR3 CL10 DIMM (kit of 8) Beast series XMP |
KHX21C11T3FK8/64X | 64GB 2133MHz DDR3 CL11 DIMM (kit of 8) w/fan Beast series XMP |
1 Please check your favorite Kingston e-tailer or reseller for pricing.
Kingston HyperX black Memory1 |
KHX13C9B1B/4 | 4GB 1333MHz CL9 DIMM black series |
KHX16C9B1B/4 | 4GB 1600MHz CL9 DIMM black series |
KHX13C9B1B/8 | 8GB 1333MHz CL9 DIMM black series |
KHX13C9B1BK2/8 | 8GB 1333MHz CL9 DIMM (kit of 2) black series |
KHX16C9B1BK2/8 | 8GB 1600MHz CL9 DIMM (kit of 2) black series |
KHX16C9B1BK2/8X | 8GB 1600MHz CL9 DIMM (kit of 2) black series XMP |
KHX16C10B1B/8 | 8GB 1600MHz CL10 DIMM black series |
KHX16C10B1BK2/16 | 16GB 1600MHz CL10 DIMM (kit of 2) black series |
KHX16C10B1BK2/16X | 16GB 1600MHz CL10 DIMM (kit of 2) black series XMP |
