Best of a laptop, best of a tablet.
Barely tipping the scales at .79 kgs, the new 12-inch Surface Pro 3 has all the power and performance of a premium laptop in a thin and lightweight design. It also comes with the all-new Surface Pen which delivers a natural writing and drawing experience.
Larger screen, lighter form
Featuring a gorgeous 12-inch display encased in a sleek magnesium frame, Surface Pro 3 is the thinnest and lightest in our Pro family. Refined to its essential elements, Surface Pro 3 is as beautiful as it is functional so you can stay productive from anywhere. Just slip it into your bag or backpack and go.
Run your favourite programs and apps
Pre-loaded with Windows 8.1 Pro, you can install your favourite desktop software, including the full Microsoft Office Suite1 and thousands of programs created for the Windows platform. Surface Pro 3 also has a 4th generation Intel Core processor which delivers blazing-fast performance.
Revolutionary laptop
Offering unmatched versatility, you can go from tablet to laptop in a snap with the multi-position Kickstand and Surface Pro Type Cover.3 Magnetic stability keeps the Surface Pro Type Cover steady, so you can work just as comfortably on your lap as at your desk. Plus, you can easily connect your peripherals and transfer files via a full-size USB 3.0, microSD card reader and Mini DisplayPort.4
Write naturally
Behold the most natural writing and drawing experience on a tablet thanks to the new Surface Pen. Use the Pen to mark up presentations, sign documents or enjoy art apps. You can also open a blank OneNote document with a click of the Surface Pen to instantly capture your next idea–even if your device is in sleep mode.
Surface Pro 3 vs. MacBook Pro
Surface Pro 3
MacBook Pro
Travel
Substantially thinner and lighter, weighs .79 kgs
13-inch MacBook pro tips the scales at 1.57 kgs
Touch
10-point, multi-touch screen
Non-touch screen
Laptop & Tablet
Detachable keyboard3 and touch screen makes Surface Pro 3 a tablet when you want and a laptop when you need it
No touch screen. Non-detachable keyboard available
Get work Done
Runs entire Office Suite1 and thousands of programs created for the Windows platform
Runs Office, but can’t run many software programs you may need to get work done
Write Naturally
High-quality Pen that delivers a natural writing and drawing experience
No pen and no pen support
Capture the Moment
Two 5MP HD front- and rear-facing cameras
One 720p HD front-facing camera
Tech specs
Software
Windows 8.1 Pro
Exterior
Dimensions: 292.1 x 201.4 x 9.1 mm • Weight: .79 kgs • Casing: VaporMg • Colour: Silver • Physical buttons: Volume, Power, Home
Storage
64GB, 128GB, 256GB or 512GB2 • 64GB has >36GB available disk space • 128GB has >96GB available disk space • 256GB has >211GB available disk space • 512GB has >450GB available disk space
Display
Screen: 12″ ClearType Full HD Display • Resolution: 2160 x 1440 • Aspect Ratio: 3:2 • Touch: 10-point multi-touch
CPU & Wireless
4th generation Intel Core i3, i5 or i7 Processor options • System memory: 4GB or 8GB • TPM Chip for enterprise security • Wireless: Wi-Fi 802.11ac/802.11 a/b/g/n • Bluetooth 4.0 Low Energy technology
Battery Life
Up to 9 hours battery life
Cameras, Video & Audio
Two 5MP HD cameras, front and rear-facing • Stereo microphones • Stereo speakers with Dolby sound
Ports
Full-size USB 3.0 • microSD card reader • Headphone jack • Mini DisplayPort • Cover port
Sensors
Ambient light sensor • Accelerometer • Gyroscope • Magnetometer
Warranty
1-year limited hardware warranty6
Surface Pen
Dimensions: 135mm (length), 9.5mm (diameter) • Weight: 20g +/- 2.0g
Pre-installed Apps
Flipboard • Skype Wi-Fi • Skype • OneNote MX • Solitaire • Mahjong • Sudoku/Microsoft Number Puzzle • Fresh Paint • Note Anytime
In the box
Surface Pro 3 • Surface Pen • 36-watt power supply • Quick Start Guide • Safety and warranty documents
FAQ
Can I run everything on Surface Pro 3 that I can on my laptop or desktop?
A: Yes, Surface Pro 3 is a full laptop replacement.
How does the magnet on the keyboard work?
A: The magnet is designed to increase the on lap typing experience. Simply connect the magnet to the bottom of the device.
Does Surface Type Cover and Type Cover 2 work on Surface Pro 3?
A: Surface Pro 3 works best with Surface Pro Type Cover, however your Touch and Type Cover 2 will click in and work with Surface Pro 3.
1Office sold separately.
2System software uses significant storage space. Available storage is subject to change based on system software updates and apps usage. 1GB = 1 billion bytes. For more information, seesurface.com/storage.
3Surface Covers sold separately
4Adapter required, sold separately.
5Up to 9 hours of battery life for video playback. Battery life for other uses will vary.
6Your new Surface comes with a one-year limited hardware warranty and 90 days of technical support.
*System software and apps use significant storage. Learn more >
