OCZ Vertex 2 E 60GB OCZSSD2-2VTXE60G Review
bluetooth 15 Aug 2010
HDD used to be the bottleneck for performance. This has been partially solved with higher SATA interface speed. As HDD goes speedier, it is still unable to saturate the interface. SSD came and slowly take over as the preferred choice as storage media as it is speedy and could take advantage of the higher speed SATA II interface. As not all SSD are made equal, some SSD gives amazing read speeds but bad write speeds. OCZ Vertex II 60GB, the extended version inherits the original version with a bigger capacity and push the limits in both sequential and random read/write. As spec, it is able to do a max read and write up to 285MB/s and 275MB/s respectively. 4K random write (aligned) should be able to attain 50,000 IOPS. by virtue of the SandForce controller.
Built with SATA 3Gb/s, the Vertex 2 Series easily integrates into today’s mobile and desktop platforms and features TRIM support to optimize performance over the drive’s lifespan as the ultimate Windows 7 notebook or desktop upgrade.
The OCZ Vertex II 60GB comes with a metal bracketl 2.5” to 3.5” adapter so you can stick the SSD into a standard hard drive bay. Below is a video showing the package and the SSD.
Specifications
Max Read: up to 285MB/s
Max Write: up to 275MB/s
Sustained Write: up to 250MB/s
4k Random Write (Aligned): 50,000 IOPS
Seek Time: 0.1 MS
Power Consumption: Idle: 0.5Watts Active: 2Watt
Performance Optimization: TRIM (requires OS support)
[…] OCZ Vertex 2 E 60GB OCZSSD2-2VTXE60G Review […]
