Intro
Contents
Oppo Reno8 Pro 5G is the successor to the mid range Reno 7 Pro 5G. Sharing a common camera setup, the Reno8 Pro is enhanced with the Marisilicon X NPU.
On first sight, the Reno8 5G Pro 5G feature a Streamlined Unibody Design that looks very similar to the Find X5 Pro 5G especially when it is observed from the back.
It has a 6.7-inch Ultra-Clear AMOLED display with a 93.4% screen-to-body ratio, 120Hz refresh rate and supports 1 billion colours for a guaranteed smoother and more comfortable viewing experience with enhanced interaction. The display is also HDR10+, SGS Low Motion Blur and SGS Low Blue Light certified, and HD & HDR certified for Amazon and Netflix. Measuring just 7.34 mm in thickness, and weighing just 183 g, Reno8 Pro 5G is the thinnest Reno series handset to date and is available in two new stunning colour finishes – Glazed Green and Glazed Black.
Similar to the Reno7 Pro 5G, the Reno8 Pro 5G is powered by MediaTek Dimensity 8100-MAX 5G SoC which supports 5G NSA/SA networks which works with the local telco’s 5G SA (M1) or 5G NSA network (Gomo, SIMBA)
In terms of battery, Oppo Reno8 Pro 5G comes with a 4500mAh battery and it supports 80W SuperVOCC charging gives you 50% with a 11 Minutes Charge.
In terms of camera setup, the Reno8 Pro 5G shares the same sensors used on the Reno7 Pro 5G, the Sony IMX 709 front camera and Sony IMX 766 for back camera. There is also a 8MP wide angle and 2 MP Macro at the back panel.
Sony IMX709 is a next-generation RGBW 32MP camera sensor customised by OPPO. It ensures a 60% increase in light intake and a 35% improvement in noise reduction when compared with traditional RGB sensors. Together with OPPO’s self-designed Quadra Binning algorithm, every selfie will look dynamically bright and sharp no matter in lowlight or backlight scenes. IMX709 also supports AutoFocus on the front camera for the first time, enabling 2x zoom when taking selfies. With a minimum focal distance of 15cm, it’s possible to capture super close-up shots using the front camera, offering unprecedented detail in selfies.
Sony IMX766 is a 1/1.56-inch 50MP main camera sensor with 1.0um large pixel size. It captures more lights and guarantees an improved image brightness in dark environments. Combined with the All-Pixel Omni-Direction PDAF technology, this camera sensor improves focus speed, accuracy, and stability.
OPPO Reno8 series also comes packed with a series of portrait features driven by leading AI technologies.
- Ultra Night Video algorithm enhances the image quality, colour expression, and facial performance in lowlight environments, delivering sharp and bright night portrait videos. It is automatically enabled for nighttime shooting.
- Ultra HDR Video mode prevents bright parts from over-exposure and enriches dark parts with subtle details, thereby producing natural portrait videos with vivid colours. It is automatically enabled in scenes with a large lighting ratio.
- Night Portrait leverages industry-leading Turbo RAW algorithm to perform AI noise reduction in the RAW domain, delivering clear and pure portrait images.
Powered by MariSilicon X and the Dual Sony Flagship Sensors, Reno8 Pro 5G also provides a flagship-level portrait camera experience for the first time at this price point by bringing 4K video shooting to a smartphone with 4K Ultra Night Video and 4K Ultra HDR Video.
Specifications
