Unigine Valley and Heaven Benchmarks
Unigine Heaven is run at Extreme and Valley is at ExtremeHD. which uses the resolution of 1920×1080.
Both benchmarks were tested using the same graphics card and drivers.
The results are quite similar as we see that the GPU could be the bottleneck. Nevertheless, the processors are able to churn out pretty good results that are quite similar to the higher end processors.
Likewise for Unigine Valley, the difference in results aren’t that noticeable.
