Slide out keyboard of the Nokia C6
The Nokia C6 comes with a slide out keypad. Compared to the keyboard on Motorola Milestone, the Nokia C6 keypad feel is way better. It is pretty comfortable typing on the keypad than on touchscreen. You can also use the cursor pad on the right to manuvere the pointer.
