Intro
Introduction
If you are an avid fan of Google home devices, you are probably familiar with the Google Home series.
Google Nest inherits the best from the Google Home. With Google Assistant, it can be the command centre to your connected devices while act as a powerful audio device that will fill your living room with music.
The new Google Nest Audio speaker sounds like a booming speaker. It is 75% louder and has 50% stronger bass than the original Google Home (which we already thought had great bass.)
This is made possible with it’s 19-millimeter tweeter and 75-millimeter mid-woofer. The Google Nest Audio has a dimension of 6.89 x 4.89 x 3.07 inches and weighs 2.65 pounds.
At a price of S$139, it seems to be pricey as you will need to get a pair for Stereo pairing.
So, how does it sound as compared to the Google Home ? We check that out in the video on the next page.
