Specifications
Contents
Unboxing and Specifications
Dimensions & weight
Height: 175 mm
Width: 124 mm
Depth: 78 mm
Power cable: 1.5 m
Device weight: 1.2 kg (without external power adaptor)
Colours
Connectivity
Power and ports
Speakers and mics
Technology
Sensors
Processor
Supported operating systems for Home app
What’s in the box
  • Google Nest Audio
  • Power adaptor and cable
  • Documentation bundle
Requirements
  • Wi-Fi use requires 802.11a/b/g/n/ac access point (router)
  • Nearby electrical socket
  • Google Home app running on a compatible mobile device. Minimum operating system requirements can be found at g.co/home/req.
