UGREEN is a company that manufactures a wide range of electronic accessories. Their product portfolio includes charging devices, mobile-phone and computer accessories, hubs & adapters, cables and more. They focus on creating reliable and effective products that help users stay connected while on the go.
https://shope.ee/6KXQgdSIE8 at S$43.59
The UGREEN 65W 4-Port GaN Charger is a powerful and versatile charger that can charge up to four devices simultaneously. It features advanced Gallium Nitride (GaN) technology that allows for high-speed charging and efficient power distribution among its ports. With its compact size and foldable plug, it’s the perfect travel companion for all your charging needs.
The Ugreen 65W GaN charger is an inexpensive four-port charger that can replenish practically any mobile device. It has three USB-C ports and a USB-A port, and supports fast-charging protocols (QuickCharge 4.0 and USB Power Delivery 3.0). The charger also supports other fast charging protocols including FCP, PPS etc.
This charger is compatible with a wide range of devices including MacBook Pro/Air, Dell XPS 13, iPad Pro, iPhone 14/14 Pro/14 Pro Max/13, Galaxy S22 and more. It delivers up to 65W of power to charge most devices at full speed. Thanks to its Intelligent Power Distribution technology, it optimizes battery charging by distributing power among its ports.
The USB port 1 and 2 can deliver a max of 65W while the 3 port is at a max of 18W.
The USB A port has a maximum output of 22.5W.
The 4 port USB C Charger comes with PD 3.0,outputing Max.65W power with single USB C port, which can charge your MacBook Pro 13″ fully in 1.8 hours. The USB C power adapter is not only compatible with PD 3.0, but also Quick Charge 4.0, 3.0,Samsung PPS,AFC, Huawei SCP for the USB A Port.
Here is how the wattage will be distributed
In our own test, it took around 28 minutes to charge our Redmi Note 11 Pro 5G smartphone from 0% to 50% and 1 hour to charge it to 100%.
In summary, this 65W device boasts a small and compact design, making it ideal for both home use and travel, particularly for individuals who require simultaneous charging of multiple devices, including smartphones and notebooks.
You can purchase it at this link below
Pair it up with the 100W USB C cables
https://shope.ee/7A6XiCMcVM at S$7.99
