The three Singapore telcos, M1, Starhub and Singtel has already announced their price plans for the new Apple iPhone 4S that goes on sale on 28 OCT 2011.
We have consolidated the various price plans into this chart for your easy reference. So, which telco give you the best deal? Let’s analyse it for you.
If you are on a budget constraint and wants the latest gadget at minimum cost, the M1 plan seems to be the cheapest among the three telcos. At S$36 a month, you get the same amount of local outgoing minutes. Other than the iPhone 4S 16G is $7 more expensive than the two other telcos, the 32GB and 64GB model are relatively cheaper than Singtel and Starhub.
What about the S$56-$59.90 range plans ? For this plan, M1 again is the cheapest in terms of per month subscription.  Data bundle are all 12 GB. SMS doesn’t really matter as you can use Whatsapp or imessaging  on iOS.  Other than it’s pricing of iPhone 4S 32GB which is more expensive than Singtel, both Starhub and Singtel can’t match M1’s pricing.
As for the $98-$99.99 range, M1 again seems to edge out the two competitors. It has unlimited data bundle. So, you can use this plan to replace your broadband if the HSPA speeds are good at your location. With unlimited data, you can make SKYPE calls, download videos without worry. M1 is also generous to provide 700 minutes of outgoing calls. The price for it’s 4S 32GB is also cheapest of all. As for iPhone 4S 64GB, Singtel is $2 cheaper but you pay $2 more monthly for the subscription.
Now, the highest plans. M1 again is cheapest at S$198. Singtel and Starhub both has 2000 minutes and 2000 SMS bundled in. M1 on the other hand gives you unlimited incoming calls. Data is both unlimited on M1 and Starhub but capped at 30GB for Singtel. You don’t have to pay upfront for iPhone 4S 16GB and 32GB models. As for iPhone 4S 64GB model, Singtel is $7 dollars cheaper than M1 at S$115 and Starhub at S$128.
Before you decide on which operator and plan to take. It is important to know some of the perks that are available on the various networks. Among the 3, Singtel and Starhub both has 3G video streaming from their pay tv service. M1 on the other hand lacks out this feature.
Secondly, Singtel so far has the widest coverage and signal shouldn’t be an issue in most parts of the country. The other two operators do have good signals in prominent towns and in city area. 3G signal coverage is not as far reach as Singtel.
Thirdly, you have to consider the network. If you use the data bundle for serving internet, which one gives you a better experience in terms of speed and loading?
Fourthly, if you travel often, you might want to check who are their roaming partners. Certain roaming partners offer better roaming rates if you log into their network when overseas.
So, good luck and enjoy your new iPhone 4S. Any comments, please post them at this link http://forums.ocworkbench.com/showthread.php?p=488156#post488156
Comment at the end of the post.
One thought on “Singapore telcos iPhone 4S Price plan comparison chart”
  1. Wow! This blog looks exactly like my old one!
    It’s on a completely different subject but it has pretty much the same page layout and design. Outstanding choice of colors!
Comments are closed.
