Looking for the most affordable featured pack board. You would not want to miss out the ASRock X58 Extreme6. This board is the first board based on Intel X58 chipset and it support up to 6 USB 3.0 ports on board. ASRock uses 3 NEC USB 3.0 chipsets to control the 4 rear 2 front USB 3.0 ports. In order to supply ample bandwidth, ASRock uses the PLX chip on board.
Below are some pictures of the board and packaging. Look out for our review and lucky draw for ASRock front USB 3.0 boards in the coming weeks (announcements will be made in the forums and news).
ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
Six-Core CPU Ready
Supports Triple Channel DDR3 2000(OC)
Supports ATI™ Quad CrossFireX™,3-Way CrossFireX™ and CrossFireX™
Supports NVIDIA® Quad SLI™,3-Way SLI™ and SLI™
2 x Front USB 3.0 ports, 4 x Rear USB 3.0 ports, 6 x SATA3 6.0 Gb/s connectors, 2 x IEEE 1394 ports
Dr. Debug, Smart Switch Design: Power/Reset/Clear CMOS Switch with LED
Supports ASRock Instant Boot, Instant Flash, OC Tuner, IES, OC DNA, Good Night LED, Multi-Speed Fan Control, AIWI, APP Charger
Combo Cooler Option (C.C.O.)
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), THX TruStudio Pro™ and Premium Blu-ray audio support
Free Software : CyberLink DVD Suite – OEM and Trial
Free Bundle: 1 x Front USB 3.0 Panel, 1 x ASRock SLI_Bridge_2S Card, 1 x ASRock 3-Way SLI-2S2S Bridge Card
ErP / EuP Ready
