Just saw this interesting USB stick which allows one to watch DVB-T2 and even Cable (unencrypted) channels via USB port connected to a PC.
It is priced at SGD 33.00 on lazada.sg. If you want to receive the local terrestrial digital broadcast via your notebook, this small little USB stick might help. It would be fantastic if it is connected to the cable point as it should be able to decode DVB-C channels (unencrypted).
For radio listeners, there is a FM tuner and DAB (if you are in the UK, you probably can make use of this).
The downside of this device is that it doesn’t seem to have a HDMI out. The only way to watch the broadcasts is only via a PC or notebook with the accompanying software inside the CDRom.
