• 5600 CL36-36-36-76 1.2v to 6400MHz CL32-39-39-102 1.4v
  • Available in 32GB (2x16GB) memory kits
  • Superior overclocking performance with HYNIX IC
  • SCC 2+2 KIT (Patent NO. US-10,285,273 B1)
  • Intel XMP 3.0-Ready
v-color, a leading memory provider, announces the launch of Manta XPrism RGB DDR5 gaming series, with speeds of 5600 CL36-36-36-76 1.2v to 6400MHz CL32-39-39-102 1.4v. Available in dual channel kits of 32GB (2x16GB) using carefully sorted Hynix ICs for superior overclocking performance, the Manta XPrism RGB DDR5 is designed for the latest 12th Gen Intel Core desktop processors and Intel Z690 chipset motherboard and is XMP 3.0 ready for easy overclocking. To fully complete PC builds, v-color also offers patented SCC 2+2 KIT, available in black and white, for filling unused DIMM slots.
Ultra-low Latency DDR5 with Overclocking Performance
The Manta XPrism RGB comes in 32GB (2x16GB) modules and offers high-speed performance ranging from 5600MHz to 6400MHz. The XPrism RGB is XMP 3.0 ready for optimal frequencies by simply applying profiles in the BIOS. Additionally, each Manta XPrism RGB goes through v-color’s patented auto-screening process (Advanced O.C Smart Sorting System).
Overclocking, Stable, and High Tolerance
The Manta XPrism RGB uses Hynix ICs for superb overclocking performance, great stability, and a high tolerance for heavy workloads. At 5600MHz @1.2V, 6000MHz @1.25V, 6200MHz @1.3V, and 6400MHz @1.4V, the Manta XPrism RGB series features the perfect balance of frequency and power delivery. Thanks to the onboard PMIC (Power Management Integrated Circuit) chip and on-die ECC chips, each Manta XPrism RGB performs at stable frequencies.
Custom-designed Cooling in Style
The Manta XPrism RGB can handle the additional heat of DDR5 with custom-designed heat-dissipating heatsinks, available in black and white. In addition, each stick features 16 addressable LEDs embedded behind a meticulously carved diffuser that ensure smooth light effects and ultimate brightness. The Manta XPrism RGB is compatible with all motherboards lighting software enabling users to create a unified look across their system.
Fill up empty DIMM slots with SCC 2+2 KIT
v-color provides the option of using Manta XPrism RGB SCC kits (Patent NO. US-10,285,273 B1) to fill up the remaining DIMM slots for builds to look more complete with fully addressable stunning light effects.
Pricing and Availability
v-color Manta XPrism RGB DDR5 6400MHz32GB (2x16GB) MSRP 539.99
v-color Manta XPrism RGB DDR5 6400MHz32GB (2x16GB) plus SCC 2+2 Kits MSRP 599.99
v-color Manta XPrism RGB DDR5 6200MHz32GB (2x16GB) MSRP 399.99
v-color Manta XPrism RGB DDR5 6200MHz32GB (2x16GB) plus SCC 2+2 Kits MSRP 459.99
For more information
Manta XPrism RGB DDR5 Specifications
Part NumberH/S ModelMemory Capacity (units per pack)FrequencyCAS LatencyVoltage
TMXPL1656836KWKBlack32GB (2x16GB)5600MHzCL36-36-36-761.2V
TMXPL1656836WWKWhite
TMXPL1660836KWKBlack32GB (2x16GB)6000MHzCL36-38-38-761.25V
TMXPL1660836WWKWhite
TMXPL1662836KWKBlack32GB (2x16GB)6200MHzCL36-39-39-761.3V
TMXPL1662836WWKWhite
TMXPL1664832KWKBlack32GB (2x16GB)6400MHzCL32-39-39-1021.4V
TMXPL1664832WWKWhite
