ASUS launches 4 socket fm2 boards F2A85 series motherboards. There are one matx and one full atx board.
The 4 boards are F2A85-V Pro, F2A85-M Pro, F2A85-M and F2A85-M LE.
All 4 boards supports the new socket Trinity FM2 processors. Chipset on board is the new AMD A85X FCH (Hudson D4).
For RAM support, other than the F2A85-M LE, the 3 other boards support 4 DIMM slots of up to DDR3-2400 (OC). AMD official spec for the FM2 is DDR3-1866. The F2A85-M LE supports only 2 DIMM Slots.
The F2A85-V Pro supports 3 single @16 or dula @ x8/x8 and 1 PCIe x4. The F2A85-M Pro supports 2 PCIe slots supports single 16x or dual 8x. The F2A85-M and F2A85-M LE supports 2 slots in either single x16 or dual @ x16/x4.
Graphics controller is built into the APU and supports Radoen hD 7600 series graphics and also support DX11 and CrossFIRE X.
The F2A85-V Pro and F2A85-M Pro supports Display port in addition to HDMI/DVI/D-SUB. The F2a85-M and F2A85-M LE do not support Display Port.
The audio used on the 2 higher end models are ALC892 while the two lower end uses ALC887. All board uses Realtek 8111F GbE LAN and has 7 SATA 6Gbps and 1 eSATA 6Gbps native ports.
The two higher end boards include 6 USB 3 and 10 USB 2.0 while the 2 lower end has 4 USB 3 and 10 USB 2.0 ports.
As we have mentioned that some newer board supports Virtu MVP, The ASUS does not seem to support it.
Stay tuned for more news at ocworkbench and post your comments here or in our forums or facebook.
WHERE ARE THE PRICES?????
