Corsair Ushers in Next-gen PC Platforms
with Vengeance LPX and Dominator Platinum DDR4 Memory
Corsair DDR4 paves the ways for next-gen PCs with higher data bandwidth, lower power consumption, and higher reliability
FREMONT, California — August 14, 2014 — Corsair®, a leader in high-performance PC hardware, today announced the availability of Corsair Vengeance® LPX and Dominator® Platinum lines of high-speed DDR4 computer memory. This new generation of memory ushers in a new age of ultrafast computing with optimizations such as increased DRAM bandwidth, higher bus frequencies, lower power usage, and higher reliability.
Corsair Vengeance LPX and Dominator Platinum DDR4 memory kits are validated with motherboard partners (ASUS, ASRock, EVGA, Gigabyte, and MSI) and use the new XMP 2.0 profile to deliver easy, reliable overclocking performance with the upcoming next-generation Intel® X99 platforms and Intel® Core™ i7 processors (codenamed Haswell-E). The Vengeance LPX and Dominator Platinum memory kits are supplied with a limited lifetime warranty.
Vengeance LPX
corsair-1
Vengeance LPX memory is a new Corsair memory line designed for high-performance overclocking with a low-profile heatspreader is made of pure aluminum for faster heat dissipation and the eight-layer PCB helps manage heat and provides superior overclocking headroom. The memory kits are available in black, red, white, or blue so that enthusiasts, gamers, and modders can add a touch style to match the color scheme of their PC.
Dominator Platinum
corsair-2
Like the DDR3 memory versions, the new Dominator Platinum DDR4 memory kits have a striking industrial design for good looks, patented DHX technology for cooler operation, user-swappable colored “light pipes” for customizable downwash lighting, and Corsair Link compatibility for real-time temperature monitoring. Dominator Platinum memory is built with hand-screened ICs, undergoes rigorous performance testing, and incorporates state-of-the-art cooling for reliable performance in demanding environments.
Vengeance LPX and Dominator Platinum DDR4 Specifications
Unbuffered DDR4 SDRAM in 288-pin DIMM
Capacities at launch: 8GB (2x4GB), 16GB (4x4GB), 32GB (4x8GB) and 64GB (8x8GB)
Speeds at launch: 2666MHz, 2800MHz, and 3000MHz
Intel XMP 2.0 (Extreme Memory Profile) support
About DDR4
DDR4 is faster.
Even at the baseline speed of DDR4 delivers twice the bandwidth with 2133 MT/s (million transfers per second) compared with the base DDR3 1600 MT/s. With optimizations games and applications have the potential to load faster and run more smoothly.
DDR4 uses a lot less power and runs cooler.
With each new generation of CPU and GPU architecture, system power consumption and heat generation become more and more important. DDR4 modules operate at an ultra-low standard 1.2 volts compared to the 1.5 and 1.65 volts of DDR3 memory, allowing DDR4 memory to consume significantly less power and generate less heat.
DDR4 memory modules can get bigger.
DDR3 is limited to 8GB modules for a maximum of 32GB on standard four-socket motherboards. DDR4 will have the ability to enable 16GB per module by 2015. A motherboard with eight memory slots will be upgradeable to an amazing 128GB or DDR4 memory.
Pricing, Availability, and Warranty
Corsair Vengeance LPX Series and Dominator Platinum DDR4 memory kits will be available at the end of August from Corsair’s worldwide network of authorized distributors and resellers. The Vengeance LPX and Dominator Platinum memory kits are supplied with a limited lifetime warranty and are backed up by Corsair’s customer service and technical support.
