Cinbench 11.5 x64
Cinebench 11.5 64 bits edition was run on against the test platform. The result is 3.16 which is slower than the 3.22 on the two other boards (running on Win32 platform). At overclocked speeds, it secure 4.18 , far surpassing 3.79 on the two other boards.
In the OpenGL test, the default test scores 33.42 fps which is higher than the two other boards. When it comes to overclocked mode, it only push it slightly higher at 35.63fps. The score is on par with the Gigabyte A75-UD4H but falls why from the ASRock at 40fps.
