Benchmarks - Cinebench R15 and SiSoft Sandra 2018
Contents
Benchmarks – Cinebench R15 and SiSoft Sandra 2018
Buy AMD Ryzen 3000 series processors from Amazon(US)
Benchmark – Cinebench R15
Cinebench is a popular benchmarking tool that shouldn’t be stranger to our readers. Cinebench CPU test uses all of your system’s processing power to render a photorealistic 3D scene (from the viral “No Keyframes” animation by AixSponza).
This scene makes use of various algorithms to stress all available processor cores. In fact, CINEBENCH can measure systems with up to 256 processor threads.
This test scene contains approximately 2,000 objects which in turn contain more than 300,000 polygons in total, and uses sharp and blurred reflections, area lights, shadows, procedural shaders, antialiasing, and much more. The result is displayed in points (pts). The higher the number, the faster your processor.
Cinebench also tests the single thread performance and the results have improved over the 2nd generation processors. It can easily break the 200 cb mark and is closing up the gap with Intel counterparts e.g. the Intel Core i7-9700k. The Ryzen 7 2700X merely can get around 180 cb. There is ~ a 12 % increase in single core performance compared to the 2nd generation processors.
When it comes to multithreaded performance, the Ryzen 9 3900X is now almost on par with the HEDT processors e.g. ThreadRipper 2950X. In fact, it already surpassed ThreadRipper 1950X and Intel Core i9-7900X.
As for the Ryzen 7 3700X, there is a jump of over 300 points over the Ryzen 7 2700X. There is a 16% difference lead in performance.
Ryzen 5 3600X scores 1580 which is pretty decent for a mid low range 6 core processor. It even outperform the Intel Core i7-9700K when overclocked to 5 GHz.
SiSoft Sandra 2018 Titanium SP2 benchmark
We ran the SiSoft Sandra 2018 Titanium SP2 benchmarks for overall processor score. This test runs tests on cryptography, scientific analysis, image processing etc. Some of the tests like financial analysis are very demanding and could cause system hangs if the system is unstable.
Yes, you are right the AMD Ryzen 5 3600X actually outperformed the Ryzen 7 2700X in Sandra overall processor score. The Ryzen 7 3700X is much faster than the Ryzen 7 2700X. The AMD Ryzen 9 3900X is taking away the limelight from Threadripper 1950X and is closing up the HEDT processors from both AMD and INTEL.
