PCMark Vantage
Using PCMark Vantage, we test the HDD Suite to check out the performance of the device using the various connections.
Using USB 2.0, the score is 5546 which is way lower than the USB 3.0 counterparts.
With NEC USB 3.0 controller, it achives a score of 21113. The same benchmark run on a board with Etrontech controller give a score of 22782, a 7% difference. With Xfast turned on, the speed is improved furthur to 26738 points.
