Cinebench R15
CINEBENCH is a real-world cross platform test suite that evaluates your computer’s performance capabilities. CINEBENCH is based on MAXON’s award-winning animation software Cinema 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such as Iron Man 3, Oblivion, Life of Pi or Prometheus and many more. CINEBENCH is the perfect tool to compare CPU and graphics performance across various systems and platforms (Windows and OS X).
In this test, we check out the performance per core and performance per CPU.
As we can see, when we run the Ryzen 7 2700X at defaults, the CPU (single core) scores 175 cb which is an per percent points improvement over the 1st generation Ryzen processors. You might see results that perform better. An overclock of 3 MHz on the CPU clk can easily boost this score above 180 cb.
When it comes to multithread performance, the results is clear cut. The AMD Ryzen 7 2700X when overclocked to 4.15 GHz, it boosted a score of 1890 closing to the 2000 level.
At default, the score of 1795 is higher than an overclocked AMD Ryzen 7 1800X (oc at 4 GHz). The Ryzen 7 2700X beats the Intel Core i7 8770K by a by a 24% margin (1795 vs 1442).
The Ryzen 5 2600X on the other hand scores 1412 when overclocked and 1360 at default. A 3.8% lead.
Well that’s interesting.. I donno what I can really say about it though.
I didn’t realize I wasn’t the only one interested in this. IM NOT ALONE!
