Cinebench10 and 3Dmark Vantage Benchmarks
In this test, we used 3DMark Vantage to see the impact of memory on 3D results. Using the default settings, the LoVo at DDR3-1600 CAS 9-9-27-1T definitely couldn’t outperform the expensive HyperX modules. When we increased the memory speed to DDR3-1680 at the CAS 9-9-27-1T (with an overclocked CPU at 210×15), the benchmarks improved by over 300+ points. Well, this result is partially contributed due to the higher CPU clk speed plus a higher memory bandwidth.
We take a look at the CPU performance using Cinebench10. At default (brown bars), the results seemed to edge out the more expensive HyperX at CAS 6-6-18-1T. With the overclocked speed at 210x15MHz (DDR3-1680), the performance is further improved.
1 – 1 CPU score
2- x CPU score
3- CPU speed up
4- OpenGL score
