Signal Strength and Speedtest
Contents
Signal strength of TPG
TPG seems to be using LTE BAND 40, TDD 2300MHz as shown in the test. From what we understand, it also operates under BAND 8, 900 MHz.
Here is a screen shot of the TPG signal strength tested in Woodlands Ave 9. The Huawei Nova 3i is used with 2 SIM, one from TPG and the other is a Zero1.
Here is a speedtest result conducted on the SIM.
Updated : Speed above ground from Woodlands down to Bukit Batok are generally very stable and signal is strong. Here are some speed test results. TPG seems to have the strongest signal in the WESTERN part of Singapore above ground. North Eastern is poorly covered unless you are switched to Band 40 which is probably found indoors.
Some tips I can share for xiaomi user who are unable to use VoLTE even after dialing *#*#86583#*#* and even switching VoLTE on
Go to APN setting and add this
APN: ims
APN Type: ims
do not change APN protocol
It Works on my mum’s Redmi 4A when I test TPG SIM in her phone,got VOLTE Icon after setting it and calling another phone to test, the other phone ring.
Heard from one post on the miui forum about VoLTE in singapore
http://en.miui.com/forum.php?mod=viewthread&tid=475460&page=1#pid13588733
It may not work for all xiaomi phones .e.g. Redmi 4X
Tips for those xiaomi phone which are unable to use VoLTE even after dialing *#*#86583#*#* and have carrier check disabled
go and add this apn
APN:ims
APN type/protocol: ims
Credits:
Work for me when testing on Redmi 4A
https://en.ocworkbench.com/review-of-tpg-trial-lte-network-singapore/5
Can you receive TPG signal near the singapore border of Johor eg near JB checkpoint to woodlands
Yes you can get together signal even outside city square next to UOB or Maybank
Can someone pls give me a TPG SIM? New Sim Reg is closed 🙁 csaha2014 AT gmail DOT com
Hope you can help me out. I am registering for the free SIM card for 1st 200,000
I have passed the 1st page uploading NRIC/FIN document, the next page has a problem and not able to proceed..
Mobile Service
TPG does not currently support Number Porting. Porting will be made available in the future.
I agree to get a new mobile number from TPG
Select your preferred number
Select your preferred number *
Error occur when retrieving number.
Please select a number.
Not able to proceed from here..
hi uncle bob!i think new registration closed until further notice
For the time being, if are interested, you can contact any friends that has applied 4 cards to lend one to you if they are willing.
I think their server is overloaded. THey have temporarily closed applications.
Perhaps you want to check http://www.tpgmobile.sg regularly and other FB pages for updates
when they start accepting applications again.. It is really fastest fingers fast.
https://en.ocworkbench.com/review-of-tpg-trial-lte-network-singapore/4/
List of supported VoLTE devices
Voice calls from other telcos to and from TPG doesn’t work. Only TPG <-> TPG works.
Have u try calling from tpg number to tpg number?
